lifting problem
Hello all; forklift mast won't go DOWN and won't till for. and back; when tills back - engine quick lacks power and stops immediately. However lift UP and side shifts- works OK( in both directions) : on dashboard sits and wrench light ON, no error code> any idea? thanks
  • Posted 28 Nov 2011 09:54
  • By mplco
  • joined 28 Nov'11 - 2 messages
  • New Jersey, United States
Hi
I am having the same problem, did you find the fault ?
Have checked all fuses and seat switch. Spanner and fork cut out lit on dash, no drive and no lower or tilt but side shift and raise.
thanks
Gary
  • Posted 25 Oct 2017 10:23
  • By mrforklift
  • joined 10 Aug'09 - 39 messages
  • Queensland, Australia
ECU Fuse Is OK
  • Posted 20 Feb 2012 02:49
  • By Ogie
  • joined 27 Oct'10 - 9 messages
Ogie's LIft Truck Ltd.
Thanks All Our Customers & Suppliers.
Good Day, mplco
You say the wrench & seat switch or OPS dash lights were staying on along with the the mast going up but not lowering & no tilt.
I have a 8FGU25 & thats the problem we still have not figured out. You said you adjusted the main hyd pressure at the control valve ? The deal with your sideshift being slow is that there are restrictor's in each line to the cyl that can be removed. Still I'm wondering about this pressure adjustment thing? Waiting for your reply. Thanks, Paul
  • Posted 18 Feb 2012 01:13
  • By Ogie
hello rogeriwt,
thanks for you quick respond, No- on this case all fuses was OK (I checked it @ a firts time- all of them) I got the problem: i re-adjust pressure on master valve ; but- be aware -do not lost speed on the side shift cilinder - a movement of side shaft cylinder were so slow; need to go back to close to original position.
Thanks mplco
  • Posted 3 Dec 2011 12:23
  • By mplco
Check all the fuses. I ran into this once and the material handling ecu had blown the fuse. It sounds like that is what happened to you. Good Luck.
  • Posted 29 Nov 2011 12:33
  • By rogeriwt
Rail King RK330
Maxlion FB30EH
