lift not working
Hello I bought Linde H25t with not working lift and left right move.It have errors for joystick and I changed with new one.Now no errors but still doesn't don't lift and move left right.Oil is at correct level. I checked and fuses ,cable from joystick to Ecu,all is ok.Serial number is h2s392s00992
  • Posted 7 Apr 2025 05:29
  • Modified 8 Apr 2025 05:53 by poster
  • By miroslavval
  • joined 7 Apr'25 - 11 messages
  • Bulgaria
Showing items 1 - 20 of 24 results.
By the way , when I say remove plug I am talking about plug on solenoid on hyd control valve there are three to four black square plugs
That you have to push in a wire clamp to disconnect
  • Posted 10 May 2025 05:55
  • By John_Bradley
  • joined 10 Aug'22 - 271 messages
Jb69
On hyd control valve remove the tilt plug and put it on side shift then tilt forward or back
If side shift works you have issue with wiring or hyd valve solenoid
Since you replaced LHC that eliminated it
I suspect a bad plug or bad solenoids on valve
  • Posted 10 May 2025 05:50
  • By John_Bradley
Jb69
Hi,did you repair yours?
  • Posted 10 May 2025 05:08
  • By miroslavval
  • Bulgaria
Hello, I changed ecu ,forklift start tilt work ,but lift and side shift don't work.Same as old one.I don't know what else to check.Still doesn't have any errors on dashboard.
  • Posted 10 May 2025 05:07
  • By miroslavval
  • Bulgaria
Hi both
Similar issue on our H25T 392, think ours is 2007. No lift or sideshift, but tilt works fine. Previously had joystick replaced a couple years ago but this time no code. Workshop we've sent it to have diagnosed "ECU" (presume they mean the hydraulic controller as you've been discussing) but sceptical as we have tilt.
Price we're being given for parts is a couple £k.
Could anyone advise the right P/N for the controller?
  • Posted 29 Apr 2025 23:52
  • By nspr
  • joined 29 Apr'25 - 1 message
  • United Kingdom
Just be aware that you may need to set tilt angle unless it was already set for the unit it came from and hopefully it was same upright as yours or you could have a tip over ,if you do get it working with the new control put a degree locator on mast tilt forward all the way and see what degree it is
Then same with back let me know and I can tell you if it is correct
  • Posted 26 Apr 2025 02:34
  • By John_Bradley
I think that one will work 3903601355
Is for a 392 series
  • Posted 26 Apr 2025 02:23
  • By John_Bradley
Jb69
my Lhc is 3903606382, but I didn't found cheap unit with same number. I found with is 3903601355.Bith are with same sockets.My forklift is log with only lhc module,another I think is from diesel with lhc and ecu for diesel.
  • Posted 25 Apr 2025 07:09
  • By miroslavval
  • Bulgaria
The numbers should be on LHC
The LHC and engine control are different
The LHC should be on left of engine control closest to fuses check the number on old one against new should be same when and if you do get another you will have to have a laptop with Linde program to set tilt angle , etc
  • Posted 25 Apr 2025 06:49
  • By John_Bradley
Jb69
Hello,did you know if I put lhc module with ather part number will fit.I think ather used ecu is from diesel model.
  • Posted 25 Apr 2025 06:23
  • By miroslavval
  • Bulgaria
Ok,send diagram if you have it.I think fuses didn't missing,fire relays I'm not sure will check.
  • Posted 19 Apr 2025 17:03
  • By miroslavval
  • Bulgaria
LHC- Linde hydraulic controller
  • Posted 19 Apr 2025 09:36
  • By John_Bradley
Jb69
My main concern is not bad fuse but missing fuse or relay if you had a diagram of fuse snd relay positions it would show if any are not in place or in wrong place I will check and see if I can locate the correct wiring schematic with fuse location
  • Posted 19 Apr 2025 09:30
  • By John_Bradley
No I didn't have,but all fuses are good
  • Posted 19 Apr 2025 07:37
  • By miroslavval
  • Bulgaria
Do you have layout for fuse and relays ?
If you can find the signal wire from LHC
To the coils then you can check for volts
If I remember right it will not be battery from volts
It will be around 5 volts or so from LHC to coils
You may be getting the correct signal but have a valve issue Linde is one of the units that will throw a code for any voltage interruption ie coil or wire issue.generally the wire goes from
LHC to a relay and fuse to the coil
  • Posted 19 Apr 2025 06:13
  • By John_Bradley
Jb69
I have one diagram for 393 ,but for joystick pins are same.Ecu don't recognize signal for lift and to engage hydraulic.
  • Posted 19 Apr 2025 05:40
  • By miroslavval
  • Bulgaria
Could be , but first do you have or cs. You get a wiring diagram ?
I hate to replace the LHC unless we do some test if you don't or can't get one I will see if I can
  • Posted 19 Apr 2025 05:38
  • By John_Bradley
Jb69
Hi I test it and jostick is combined.With tilt it give error ,with lift doesn't give error.Wiring to ecu double checked and is good.What you think is bad ecu?
  • Posted 19 Apr 2025 00:13
  • By miroslavval
  • Bulgaria
Easy test of new joystick with key off
Pull back a little on joystick (either one ))and hold there then start unit it should display error code if the controller is seeing that then it is reading the new joystick and as I mentioned
Either you have bad wiring to lift and side shift coils on hyd valve or bad coils or you have a faulty controller
  • Posted 11 Apr 2025 23:21
  • By John_Bradley
Jb69
Hi, If you remove the little plastic cover off the bottom of your old joystick you can actually see the tracks of the potentiometers. Spray some contact cleaner in and work a little. This may get old working again for you to prove.
  • Posted 11 Apr 2025 16:11
  • By simon_k
  • joined 31 Oct'04 - 147 messages
  • Devon, United Kingdom
Airman ENCL045
Terberg RT223
Combilift Ltd
Combilift Ltd
