leaking head plate with fittings
Hi everyone,
I have a Hyster H50 XM s/nD177B05748P
with a leaking plate on the back of the head that has
two fittings connected to it. Does anyone know what this
is for, and what is behind the plate that is leaking?
  • Posted 3 Jan 2015 04:40
  • By ernest_r
  • joined 3 Jan'15 - 2 messages
  • Louisiana, United States
The engine is a GM 2.2L and on the rear (trans.) side of the head is a plate with two elbow fittings and a cross flow hose connecting the two fittings together. It's either a heat exchanger or dual output cooling or heating lines for something. Mechanic is afraid to remove the plate without knowing whats inside as the truck is needed in service at all times, and yes the plate is leaking coolant.
  • Posted 3 Jan 2015 09:27
  • By ernest_r
What engine is it this truck? Is it coolant leaking? Coolant hose going to vaporizor??? Little more info please.
  • Posted 3 Jan 2015 08:08
  • By kevin_t
Lift Tek Elecar
