Leaking around wheel bearings
Hi,
I have a T40D with about 800 hours on it. I just bought it second hand and I'm having some issues. First it's leaking green fluid around the wheel bearing. I can only assume its transmission fluid. I removed one wheel and the wheel cylinder is dry and looks good. What is my problem?
On another issue,
My lift is very very slow. All fluids are clean and at the proper level.
Any help would be greatly appreciated.
  • Posted 13 Dec 2014 08:15
  • By Tonyd
  • joined 13 Dec'14 - 1 message
  • Virginia, United States
if you are getting any differential oil leakage from around the outside of the hub assy you probably have an axle seal bad. If that seal goes it allows fluid to enter the jack shaft and bullgear area that can fill that area up with oil and if the bullgear cover and end housing gaskets are not sealed correctly the oil will seep out.
if the gears are dry then what kind of grease is being used inside the bullgear area? It should be a EP type grease.
As far as the speed of the truck travel, you might want to check the drive pressures, linkage adjustments etc.
Is it slipping any while traveling? Try stalling the truck and check for that.
  • Posted 22 Dec 2014 04:06
ROYPOW
ROYPOW
