komatsu engine id
can any one tell me what engine will be in a 1994 komatsu fd25t 11e diesel,its badged as a komatsu on the rocker cover but there are no more details on the block, got a rattling from the timing case area ,dont know if it is gear or chain driven.thanks.
  • Posted 16 Nov 2010 03:20
  • By markg
  • joined 27 Oct'09 - 57 messages
  • n lincs, United Kingdom
Was wondering if you could provide some tips on adjusting the valves (cold) on a Komatsu FG20 / ST-4 with a Nissan 4 cyl. I don't have a manual, but was told both exhaust & intake are.016". Just don't know the firing order and which valve is intake & exhaust.
  • Posted 29 May 2016 02:15
  • By uems
  • joined 29 May'16 - 1 message
wow thanks raul thats very kind of you to go to all that trouble,much appreciated,just out of interest you dont happen to know the engine oil pressure ,have a good day
  • Posted 18 Nov 2010 05:57
  • By markg
Markg:
this is the entire info about the forklift 1994 Komatsu FD25.
if you need more about this model, pleas let me know.
MODELS FD20/30-11 W/ 4D95S-W ENGINE
ENGINE *
Make & Model (4 cyl.) Komatsu 4D95S-W
Displacement 165 cu. in.
Horsepower * 50/57 @ 2,450 RPM
Oil Capacity w/ Filter * 6.0 / 8.5 quarts
Oil Type SAE 15W40
TUNE-UP SPECS *
Firing Order 1-2-4-3
RPM to Set Timing 700 RPM
Timing - Early Style * 6 degrees BTDC
Late Style * 12 degrees ATDC
Idle RPM 650-750 RPM
No Load Governed RPM * 2,650 / 2,750 RPM
Converter Stall RPM * 2,150 / 1,950 RPM
Compression @ 300 RPM 427 PSI
Head Bolt Torque 110 ft/lbs
Valve Clearance Set Cold
Intake 0.014 in.
Exhaust 0.020 in.
TRANSMISSION SPECS
Transmission Fluid - Torqflow Dexron ATF
Case Capacity T1/T2 10.4/11.2 quarts
Pump Pressure 154-212 PSI
Converter Inlet 35-100 PSI
Converter Outlet 30-60 PSI
Fwd/Rev Pack T1/T2 154-212/125-189PSI
Lube Pressure 15-60 PSI
Inching Spool Protrusion 1.3 in. (33 MM)
HYDRAULIC SPECS
Tank Capacity 12.4 gallons
Pump Type Gear Type
Flow @ Governed RPM GPM
Flow @ Hydraulic By-pass GPM
Relief Pressure 2,650 PSI
Steer Relief Pressure 1,350 PSI
* 4D95S-W EARLY S/N 37058-104548 LATE S/N 104549~
ZB (-11)
CUSH/PNEU
Rev. 9/2008 PAGE 2
COOLING SYSTEM SPECS
System Capacity 2.6 gallons
Operating Temperature 180-190 degrees F
Fan Belt Deflection 0.50 in. @ 22 lbs
System Pressure 13 PSI
ELECTRICAL SYSTEM
Voltage 12 VDC
Alternator Output 35 amps
Cranking Voltage 9.5 VDC
Charging Voltage 12.5-15.5 VDC
DIFFERENTIAL SPECS
Oil Type SAE 90W
Case Capacity - TORQFLOW 11.6 quarts
FUEL TANK SPECS
Tank Capacity 14.5 gallons
Recommended Fuel Diesel
QUICK REFERENCE PART NUMBERS
Engine Oil Filter 600-211-6241
Hydraulic Oil Filter 3EB-66-11711
Transmission Oil Filter 3EA-15-11600
Fuel Filter - Diesel 600-311-9651
Air Filter - Inner 3EB-02-25550
Air Filter - Outer 3EC-01-11630
Hydraulic Breather Cap 3EB-66-24121
Radiator Cap CPC89C0175010
Fan Belt 6204-81-3270
Thermostat 600-421-6131
ZB (-11)
CUSH/PNEU
Rev. 9/2008
  • Posted 18 Nov 2010 04:36
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
cheers guys,thanks for the help
  • Posted 17 Nov 2010 06:53
  • By markg
Andy is right, it will be a 4D95S-1 or -W, we have just done a de- coke on one and it has timing gears.
  • Posted 16 Nov 2010 08:26
  • By danny_k
It is almost certainly a Komatsu Yanmar 4D95S or derivative of, there where several models of this engine used. From memory i think it is gear driven, but i can't be sure.
  • Posted 16 Nov 2010 03:47
  • By AndyPandy
The dot-com bubble, a period of large and rapid investments in internet-based companies, peaked in 2000 and saw the Nasdaq Composite index rise by 579%. Then the bubble imploded. As the value of tech stocks plummeted, cash-strapped internet start-ups became worthless and collapsed.
Bolzoni SpA (Group HQ)
September 23-25, 2025 - SÃO PAULO, Brazil
October 15-16, 2025 - Las Vegas, United States
November 25-26, 2025 - Singapore, Singapore
Columbia, SC, United States
Wentzville, MO, United States
Cleveland Ohio, United States
