keeps blowing the xmsn fuse
Hi Fairly new to the forkilft world. I have a yale 8k lpg machine serial number E813V04753D that will start fine but when you release the parking break it blows the xmsn fuse immediatly and dies. Now it did lose breaks the first time this happened so I put a master cylinder on it thinking it might be a safety deal. It ran for 3 days with no problems then it blew the fuse again and has no brakes. Any help would be greatly appreciated THANKS
  • Posted 14 Jul 2015 01:07
  • Modified 14 Jul 2015 01:23 by poster
  • By mech1
  • joined 14 Jul'15 - 3 messages
  • Missouri, United States
I would check all the wiring to the solenoids on the trans. These intermittent problems are the worst.
  • Posted 20 Jul 2015 22:33
  • By BREWSKI
Brewski,
I checked under the pedal nothing is in the way of the throw. It ran for 2 days last week and today it starts but when you release the park brake it blows. Thanks for the reply this thing has been a bear
  • Posted 20 Jul 2015 21:44
  • By mech1
I think you need to check under the brake pedal lever and see if it is hitting a wire harness. Your problem only appears when you have no brakes.
  • Posted 18 Jul 2015 03:50
  • By BREWSKI
Saratoga, United States
East Syracuse, United States
Columbia, SC, United States
edition #1237 - 3 July 2025
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
