Jungheinrich ERE 120 C096 E034
Hello everybody,
please help me out with my problem.
I have a Jungheinrich ERE 120 AC model displaying faultcode E096 and E034.
I have already replaced the tiller module and checked all the wiring, but couldn't find any faults with it.
The condition of the battery is ok (new).
Can someone please help me?
Regards John
  • Posted 25 Jul 2013 19:01
  • By Johnkivits
  • joined 25 Jul'13 - 10 messages
  • Gelderland, Netherlands
Something is wrong because I dont see your mail.
Try from this way nemanjaomstill at gmail dot com
  • Posted 9 Aug 2013 07:30
  • By nemanja_k
  • serbia, Serbia
It should be on it's way, I've sent it to the adress that's on your profile.
Greetings John
  • Posted 8 Aug 2013 05:40
  • By Johnkivits
John I dont have nothing on mail from you,Did you write on good mail?
  • Posted 8 Aug 2013 02:06
  • By nemanja_k
  • serbia, Serbia
Please see mail,
Thanks, John
  • Posted 7 Aug 2013 07:15
  • By Johnkivits
Hello
Did you finish your problem?
Do you still need help I can look it for you now.My mail is in profile
  • Posted 7 Aug 2013 07:09
  • By nemanja_k
  • serbia, Serbia
Thanks!
  • Posted 26 Jul 2013 23:47
  • By Johnkivits
Just give me few days and I will look it for you
Thanks
  • Posted 26 Jul 2013 23:44
  • By nemanja_k
  • serbia, Serbia
The serial number is: 90197034.
The initial faults were C016 and E025. Therefore I've replaced the rpm-sensor bearing, but it had no effect. Then I've replaced the logic controller and that aldo had no effect.
Last I've changed the tiller unit and the faults were gone fore a few days.
Now the last few days the truck has faultcodes E096 and E034.
I've already checked the wiring loom but no problems were found.
Strange thing is that E096 stands for no zero position, the truck has only on/off push buttons.
I hope you can help me out.
Regards John
  • Posted 26 Jul 2013 22:55
  • By Johnkivits
Hello John
E 096 no zero position for hydraulic/solo pilot or multipilot
E 034 can bus damaged
From this error I think that your electronic unit dont work(have problem) usually is problem in her so if you have try another one.If not and you do all measurement in wiring open electronic and look for problem in it.
Send me serial and I will try to give you more info.
Good Luck
  • Posted 26 Jul 2013 07:51
  • By nemanja_k
  • serbia, Serbia
SMV (Konecranes) 4535TB5
Nagano NUL120-6
