JLG 20 DVL Serie 0130007550
Hi. We already do everything you indicate. The joystick card has already been changed, but now the new fault code presented by the platform control module is 202, can you help me solve this problem?
  • Posted 12 Oct 2019 12:58
  • Modified 25 Oct 2019 05:30 by poster
  • Discussion started by Carlos_L
Mejor Renta
if you perform the joystick calibration and the code 202 is still there then the platform control module is bad and needs to be replaced.
  • Posted 25 Oct 2019 07:56
  • Reply by swoop223
Thanks swoop223
We already do everything you indicate. and we have changed the joystick card, but now error number 202 appears, any suggestions?
  • Posted 25 Oct 2019 05:29
  • Reply by Carlos_L
Mejor Renta
JLG proceedures are as follows:
First:
try cycling the key on and off 5 times. On each key cycle wait 10 seconds before the next cycle. This should clear any faults.
When you replaced the joystick module did you calibrate it?
this has to be done before the unit will operate correctly.
Depending on the mfg date and serial number of the unit the calibration procedure is different, there are 2 different platform consoles is why.
early models have a diagnostic port on the platform console and you short pins 2 and 3 and turn unit on to calibrate the joystick.
Later models with the newer joystick console have to be done through the diagnostic interface with handset or ground control access.
  • Posted 14 Oct 2019 06:46
  • Reply by swoop223
Ottumwa, IA, United States
Harrisburg, SD, United States
Wentzville, MO, United States
edition #1235 - 19 June 2025
Taylor TT300
Unicarriers FD80-2
