I'm looking for a wiring diagram or manual
I have a Yale model MRW030LEN24TE024, serial number C821N020F. Having a intermittent side shift issue.
  • Posted 4 Oct 2014 06:06
  • By Madfish
  • joined 16 May'12 - 22 messages
  • Missouri, United States
you have to replace the cable in the mast. the metal has flexed and broken inside an unbroken insulation.
  • Posted 4 Oct 2014 11:40
I'm helping a co worker with this over the phone. But, yes the motor does run. The hoses flex. But, not getting a ground to the solenoid. Swap the wires with the tilt, loose tilt and side shift works. Leave the truck alone for a minute and everything works fine. Couple minutes, hours, or days later it looses side shift again. I'm thinking he has a ground issue in the card. Getting 24 volts on the power side, but randomly getting a ground.
  • Posted 4 Oct 2014 11:25
  • By Madfish
can you describe the "issue" further?. does the hydraulic motor fail to run?
  • Posted 4 Oct 2014 07:49
JLG G12-55A
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
