Hyster reach N40XMR won't lift, other functions work OK
Help please!
  • Posted 18 Jun 2021 05:46
  • By Motoprofi
  • joined 16 Jun'21 - 2 messages
Dz
Moto,
When moving the handle to the raise position, do you here the hydraulic motor run? If not there may be a problem with the control handle sensor. If it does run and no raise, suspect main relief valve stuck open or failed packing inside the cylinder. Also, verify all wiring at hydraulic control valve. Make sure nothing is broke or disconnected. Can you tell if the hydraulic line going to the cylinder is moving when requesting lift, should flex slightly. Test pressure with gage if needed.
  • Posted 18 Jun 2021 22:27
  • By Fishmech
  • Virginia, United States
Briefs United States
Crown RD572513TT6860R
JLG G12-55A
Noblelift
