HYSTER H50XM H177B48014B stalls after 10 seconds..... DO INEED THE SCANER TO RESET THE ECU
Hi i had a unit overheat because the belt broke off and the operator used it until it started blowing out antifreeze i replaced the belt but ever since then the unit stalls out i check the L.P. gas made sure i have 1.5 to 2.0 psi coming out of the regulator the ignition checks out ok I believe i need to reset the ecu any ideas on how to do it on this truck it does have a GM 3.0
  • Posted 11 Sep 2009 13:50
  • By marc_a
  • joined 19 Feb'09 - 31 messages
  • Baja California, Mexico
Do you still need help with this
  • Posted 18 Sep 2009 11:07
  • By Fortis
  • joined 27 Jun'09 - 4 messages
yes i do have good oil psi i also replaced the psi sending switch
thanks
  • Posted 11 Sep 2009 15:04
  • By marc_a
Do you have oil pressure? If the operator smoked the bearings the system will shut the engine down if it doesnt get oil pressure.
  • Posted 11 Sep 2009 13:59
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
