Hyster h190 trans codes
Model h190d Serial g007E02329c
this unit has transmission codes of 201, 101, 4250, _sht
can any one translate those codes ?
Thanks in advance
  • Posted 8 Jul 2011 22:46
t SHT
The ECM transmission control valve has a built-in
redundant shutdown solenoid and a pressure switch
that monitors the pressure controlled by that solenoid.
This solenoid is controlled by the APC200 using
both a high side and a low side switch.
When the controller enters shutdown mode, all four
pressure modulators are put at zero and both controlling
outputs of the redundant shutdown solenoid are
switched off.
This mode is activated when a severe internal or external
problem is detected. If it is an intermittent
problem, the controller will exit the shutdown mode
and enter the Limp Home mode.
However, in case the error is related to the pressure
feedback signal, Shutdown mode remains selected
until the controller is switched off.
When a fault related to the parameter settings located
in the FLASH memory is detected, the controller
reverts to Shutdown mode
Pressure Feedback Sensor
The pressure feedback signal is evaluated as an
ON/OFF pressure switch, with internal resistance of
2 kOhms when open and kOhms when pressurized.
If resistance is substantially lower than 1 kOhm, a
shortcut (SC) condition is assumed.
If it's higher than 2 kOhms, an open load (OL) condition
is assumed.
  • Posted 8 Jul 2011 23:20
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
Toyota 3FD100
Ncn 110TH
Ncn 110TH 2015
