hydraulic oil coming out trans dipstick very fast
I have an s50xm that is blowing hyd oil out the trans dipstick rapidly. I am guessing that it is a seal leaking from one of the hyd pumps into the trans but not real sure yet. If anyone has witnessed this before I would appreciate any info you might have. thanks for your time
  • Posted 3 Jan 2009 12:11
  • By kirby_r
  • joined 3 Jan'09 - 2 messages
  • Oregon, United States
i love electrical problems
check the hydro fluid if it is low then there is your problem. I have also run into this problem from clogged filter.
  • Posted 16 Jan 2010 09:15
  • By chuck_m
  • joined 13 Jul'08 - 9 messages
  • Illinois, United States
hydraulic system is separate from transmission. there will be a hydraulic level dipstick under the valvechest on the rightside of the truck
  • Posted 4 Jan 2009 00:47
  • By kevin_k
I believe on this model the hydraulic oil is checked from the same dipstick in the trans. the pump seal is sure looking like the problem. thanks for the help on this problem.
  • Posted 3 Jan 2009 23:35
  • By kirby_r
check that your hyd level is going down. it maybe that your engine is over revving. if the hyd level is going down then the seal in the hyd pump has gone ,it,s bolted into the transmission under the left hand side of the truck. you,ll get a fair bit of oil coming out when you pull the pump so get some trays ready and remember to reset the oil levels when you put new pump in
  • Posted 3 Jan 2009 19:50
  • By kevin_k
Jim Tompkins Jim Tompkins
Sales operations, Heli
XQ360 with SLAMXQ by Collective Intelligence Group
XQ360 with SLAMXQ
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
Crown RR5225-30TT321
Taylor TX330S
USD159,500
