How to reseal a valve cover
Greetings!
I have had trouble in the past getting aluminum valve covers with rubber gaskets to seal correctly- such as Mitsubishi/Mazda. I've tried different sealants, no sealants with little success. Am I missing something?
  • Posted 20 Nov 2010 08:24
  • By Forkliftt
  • Louisiana, United States
Thanks everyone- great ideas from all. I will apply these tips tomorrow!
  • Posted 1 Dec 2010 11:59
  • By Forkliftt
I have alawys used rtv on the 1/2 moon packing and the corners of gasket transitions on mitsus, it seems to work okay.
  • Posted 21 Nov 2010 05:27
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
hello
I usually like the rubber gasket is clean, well, if the joint is hard rubber substitute, oil lie in this together to be homogeneous surfaces in contact, check if it is bent.
  • Posted 20 Nov 2010 11:51
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
I have only ever used Loctite 515 Gasket Eliminator on the halfmoon plug and the corner of the halfmoon jogs in the gasket and it has worked fine. I try to use OEM gaskets wherever possible. If the truck has low compression and a lot of blowby, it's always hard keeping the engine dry, I usually recommend overhaul at that point.
  • Posted 20 Nov 2010 11:07
  • By steponmebbbboom
