how to manually extend forks to access battery compartment
hi guys im new here so hope im posting in the right area to start with. Two questions here
1:Our problem is that we have a very old R14 reach truck and the battery cable has broken away from inside the battery box.
The battery compartment is unlatched and only about 4 inches open.
Is there a way to bypass the hydraulics so we can pull and extend the mast to access the battery compartment?
2: And also if anyone has a maintenance manual that may be very helpful to us also.
Thanks in advance Shane
  • Posted 20 Oct 2016 17:11
  • By shane_clayton
  • joined 20 Oct'16 - 2 messages
  • Victoria, Australia
hi shane you can use another 48 volt battery with extension wire so you can plug it and start the truck. you cannot bypass the reach hydraulic unless you will unplug the reach cylinder hose and pull.
  • Posted 10 Dec 2016 07:01
  • By melvin_p
  • joined 25 Nov'16 - 15 messages
  • QUEZON PROVINCE, Philippines
Hi guys,
its been a while so i thought id just ask it again if anyone can help me out with info on my original questions:
1:Our problem is that we have a very old R14 reach truck and the battery cable has broken away from inside the battery box. The battery compartment is unlatched and only about 4 inches open. Is there a way to bypass the hydraulics so we can pull and extend the mast to access the battery compartment?
2: And also if anyone has a maintenance manual that may be very helpful to us also. Thanks in advance Shane
  • Posted 9 Dec 2016 18:07
  • By shane_clayton
UN Forklift FBT20NQZ1
Terberg RT403
ATEX MIRETTI GROUP
Miretti Explosion Proof Systems for Material Handling: for over 50 years, "Ex Atex Safety in Explosive & Hazardous Areas".
Tampa Florida, United States
