HELP! retrofitted new carburetor on Containtal F163 engine, how to adjust it
Hi there,my old Hyster had old BEAM carburetor but had vacuum leak which they are no longer make it, i found the compatible flange Impco CA125 model and fitted on the intake manifold, connected vacuum line and propane line from regulator, but i couldnt get it running, it had loud pop in the carburetor at first try and i tried again after cranking a bit then another loud pop from carburetor. i think its from the starter fluid flooded in the intake manifold, or its a lean mixture, if anyone can give me a guide how to adjust it thank you!
  • Posted 29 Dec 2023 08:40
  • Modified 29 Dec 2023 09:25 by poster
  • By walter_shui
  • joined 6 Nov'23 - 6 messages
lists are the adjustments on the carburetor:
1. idle mixture adjust screw
2. idle speed adjust (on the throttle leaver)
3. power mixture adjust valve
i have attached a link of my new carburetor installed thank you!
https://drive.google.com/file/d/1eu6YE2aOtiRNDcU8d3mSY5I1HY4mI7A9/view
  • Posted 29 Dec 2023 08:46
  • By walter_shui
Sue Tomic Sue Tomic
SMV (Konecranes) 16-1200B
Taylor X550M
Sue Tomic Sue Tomic
Taylor X550M
