Hard starting (propane and gas)
Any suggestions, the lift is hard starting on gas or propane.lift sat in warehouse for about a year before being used.
  • Posted 7 Nov 2014 08:22
  • By BassTracker
  • joined 7 Nov'14 - 5 messages
  • New Jersey, United States
thanks for info and all your time p.s did not mean to side that so many times
  • Posted 8 Nov 2014 08:30
  • By BassTracker
Once it starts- how does it run as soon as it fires on gas & lp? I would run a tank full of fresh gasoline plus an additive called "Sea foam" - I've had great luck w/ this product for cleaning out gummed up gasoline fuel systems.
As far as the lp fuel system- no fuel system cleaners as of yet. If it won't start on LP then a system rebuild is in order.
  • Posted 8 Nov 2014 08:01
  • Modified 8 Nov 2014 08:03 by poster
  • By bbforks
OK OK NO NEED TO YELL ABOIT IT....LOL
being that its sat for a year it could be that the duel system is all gummed up on both the gas and lpg side.........ignition and injection is controlled by signals from the cam/crank signals somcould be a weak signal there at cranking. Also check and clean or replace the MAF sensor this plays a part in it also.
I would start by getting one fuel system to work/operate properly by either going thru the gas sytem and changing the filter and cleaning the injectors somehow. On the lpg side i would start by cleaning or rebuilding the NIKKI regulator and checking the injector holder and injector and cleaning any tar junk out.....
  • Posted 8 Nov 2014 07:24
  • By kevin_t
THIS HAS FUEL INJECTION
  • Posted 8 Nov 2014 06:52
  • By BassTracker
USED NGK IT IS K25D HAS FUEL INJECTION YR 2005
  • Posted 8 Nov 2014 06:51
  • By BassTracker
What engine does this truck have in it.....Nissan K21/25?
Hope if you changed plugs you used OEM original NGK plugs,aftermarket,parts store plugs dont work well in these nissan engines...
Guess without knowing what engine is going to be a guessing game......still might be a guessing game after that
  • Posted 8 Nov 2014 06:41
  • By kevin_t
carb may need to be cleaned or rekitted this crappy fuel we have these days
  • Posted 8 Nov 2014 06:40
  • By Dave2013
  • joined 10 Jan'13 - 20 messages
  • Oklahoma, United States
thanks we did that already
  • Posted 8 Nov 2014 04:35
  • By BassTracker
You could start by replacing the spark plugs.
  • Posted 7 Nov 2014 22:07
