hard start when cold
Hi, everyone. I have a propane powered Toyota 5fgc25 serial 5fgcu25-74699. First thing in the morning the unit cranks over 15 revolutions or so before it fires up, For the rest of the day it starts first crank. The propane lockoff valve holds vacuum and ive got the vacuum line hooked directly to the intake manifold. It is an older unit with 13000 hours. engine vacuum is about 16 inhg. Any tips or ideas would be greatly appreciated. Thanks.
  • Posted 20 Nov 2012 02:51
  • By shaner
  • joined 1 Mar'11 - 29 messages
  • British Columbia, Canada
Sounds like the regulator may be losing all the propane that is normally kept in the line between the lockoff and the regulator, or......you need to be pushing the manual primer button on the backside of the LPG regulator for cold starts.
If this truck has a Model J Impco regulator/vaporizer, there is a flat aluminum primary valve inside. This blade shaped valve has a little square of rubber in its center which seals to control liquid fuel entering the regulator. Typically, deterioration of this rubber will permit liquid fuel to enter the regulator even when the primary diaphragm has it pressed shut.
In that scenario, after the engine is shut off, liquid fuel continues to leak past the rubber face valve and given enough time it will vent all of the liquid fuel that was in the line coming from the lockoff valve.
Something you can do is to loosen the fitting on the liquid line at the regulator BEFORE you attempt to crank the engine for the the first start of the day.
If you do not see any liquid fuel escape then the blade valve inside the regulator is leaking.
If you DO see some liquid fuel escape, you probably need to press in hard on the primer button located on the backside of the regulator to give a shot of fuel into and past the secondary chamber so the engine has fuel available as soon as it starts cranking.
  • Posted 20 Nov 2012 04:09
  • By L1ftmech
  • Tennessee, United States
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
UN Forklift FBRS15KQZ2
Terberg RT223
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
