H25T (392) shutting down after 10-20mins
This truck is running fine for up to 20 mins and then shuts down, it wont restart until maybe 30 mins later. I guess it must be temperature related, but the truck is not overheating.
No error codes are shown, not even with the laptop plugged in. Whatever the problem is, it stops the ignition from working, but when the truck is running it runs great.
Any help and advice would be very much appreciated.
  • Posted 25 Jan 2018 21:11
  • By Fal141
  • joined 25 Mar'09 - 26 messages
That doesn't sound stupid at all, it just so happens that the truck does not have the proper dipstick tube, this may be an issue. I am surprised I'm not seeing an error code of sorts either on the truck display or in Pathfinder.
Ordered the correct tube, will let you know the outcome.
  • Posted 29 Aug 2018 01:28
  • By Fal141
It might sound stupid but have you checked the engine oil level?
  • Posted 13 Feb 2018 23:44
  • By duodeluxe
  • United States
duodeluxe
We now have a new flywheel sensor installed but the fault remains the same. At this stage I dont think the ignition switch is at fault. Looking more like a control board problem or wiring fault.
Thanks for the help Lindetech.
  • Posted 1 Feb 2018 21:59
  • By Fal141
It should bring up a fault code when you unplug the flywheel sensor.
What is the tip of the sensor like? Any damage?
Should have 0.5 mm gap between the sensor and flywheel when fitted.
Sounds like an electrical fault that may be heat related.
I have had strange faults before and turns out to be the ignition switch.
Have you checked this when it shuts down?
  • Posted 31 Jan 2018 18:59
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
Definitely no voltage to the ignition after shut down.
I had a look at the truck last night, it did the usual thing of shutting down within 20 mins then after unplugging the flywheel sensor, the LPG lock off and cooling fan, then plugging them all back in it fired up and ran for the rest of the night while I pressure washed it off.
Anyway, this morning its back to running and shutting down and not starting again. So last night was a red herring.
Thanks for the assistance Lindetech.
When I unplug the flywheel sensor while cranking it doesn't show any error codes, is this normal?
  • Posted 30 Jan 2018 21:39
  • By Fal141
Are you getting 12vdc to the ignition pack aftershut down?
  • Posted 30 Jan 2018 19:24
  • By Lindetech
The LPG regulator is running at normal operating engine temperature. The spark disappears after shut down.
We have fit a new ignition coil as when it was inspected it was found to be corroded around one of the connections, but the fault still remains the same.
  • Posted 29 Jan 2018 20:48
  • By Fal141
Are you still getting a spark after it shuts down?
Is the lpg regulator freezing up?
  • Posted 28 Jan 2018 17:53
  • By Lindetech
ROYPOW
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
ROYPOW
