H20E 1966 couple questions.....
I have a couple questions about a 1966 H20E 3 wheeler with a Y112 engine.
1. On the floor board, right side, there is a T handle pull cable.
It is associated with the brake system.....
What does it do and how does it work??
2. The hydraulic filter cartridge is Hyster P/N 236090 and
the gasket is 236088.
Can anyone cross the Hyster numbers to a more common brand of replacement cartridge number?
Baldwin? Purolator? Fram?
Thank You!
dk
  • Posted 17 Dec 2012 03:15
  • Modified 17 Dec 2012 03:16 by poster
  • By dkmc
  • joined 18 Oct'09 - 48 messages
Yes, that's exactly how it works.
It was awkward when I last tried to reconnect the chain with the FL tipped up on a steep angle with the engine idling in gear to keep the chain as slack as possible...... HA!
It was not slack enough, I couldn't re-connect it but I want to and I need the parking brake functioning.
Maybe that T handle is the key to success with this problem.
  • Posted 17 Dec 2012 04:43
  • By dkmc
I can't remember exactly how that worked. Hydraulic pressure was used. Starting it may cause the chain to get slack and then it goes tight when shut off.
edit, I guess you have to put it in drive too to get the chain slack. The T handle should do it.
  • Posted 17 Dec 2012 04:36
  • Modified 17 Dec 2012 04:43 by poster
Thank you,
There is a small chain under the unit that is supposed to connect to the park brake linkage. It is unhooked.
I am trying to figure out how to get that chain slack enough to re-connect it. Perhaps that handle is the key
  • Posted 17 Dec 2012 04:29
  • By dkmc
That has a automatic parking brake that comes on when the machine is in "park" or not running. If you need to move it, and it won't start, the T handle releases the brake.
  • Posted 17 Dec 2012 04:22
Thank you, yes need the gasket......it is leaking a bit...
  • Posted 17 Dec 2012 03:44
  • By dkmc
236090 will cross over to a NAPA filter#1092,might come with the gasket
  • Posted 17 Dec 2012 03:33
  • By kevin_t
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
Cyngn launches automation subscription model Mountain View, CA, United States
September confidence index jumps Fort Collins, CO, United States
