FUEL REGULATOR
ANY NEWS ABOUT FUEL REGULATORS CAUSING INJECTORS TO FAIL? FG20ST-14 MODELS
  • Posted 9 Jan 2009 06:48
  • By rplpallets
  • joined 8 Jan'09 - 17 messages
  • Wisconsin, United States
The regulator does not cause the injector to fail. However excess build up of tar in the regulator can overflow into the injector and injector housing causing the relief(s) in the injector housing to clog/stick and also can cause the injector to stick. The regulator should be drained of tar regularly during the monthly PM service to prevent this.
  • Posted 1 May 2009 02:55
  • By Jeff
  • joined 8 Feb'07 - 61 messages
There is nothing worse than a sharp image of a fuzzy concept.
-Ansel Adams
Taylor TT300
Terberg RT223
Lift Technologies Inc.
Taylor TT300
Terberg RT223
The charge carried by a bolt of lightning is so intense that it has a temperature of 30,000-degrees C (54,000-degrees F), five times hotter than the surface of the sun which is about 5,500-degrees C (10,000-degrees F).
