Free lift cylinder not moving
The hydraulics on my free lift cylinder are acting goofy. The free lift does not go up, instead the outer stages go up. When I took the cylinder apart there seemed to be a vacuum on the bottom of the cylinder, so I had to release the pressure by taking off the hydraulic lines to take it apart. I cleaned everything up put it back together and it worked fine for a little while, but went back to doing the same thing. I am stumped, any help would be appreciated.
  • Posted 22 Feb 2015 06:05
  • By roy_m
  • joined 22 Feb'15 - 2 messages
  • Indiana, United States
You need to check the poppet valve in the bottom of the free lift cylinder ram. It sounds like the valve is blocked or came apart.
  • Posted 27 Feb 2015 00:47
  • By BREWSKI
Roy,
I think I would check the main relief valve as I think it may need resetting as the tilt and aux system is operated through the secondary relief valve.
Nero.
  • Posted 24 Feb 2015 09:21
  • By NER045
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
JLG launches YouTube University channel McConnellsburg, PA, United States
