Few questions on what's wrong
Hello, I just started a new factory maintenance job in Alaska and we have a few pallet jacks that don't work. The one guy said they need new batteries but turns out they are all good.
#1 eje 120, battery light flashes when charging red, won't charge. I changed this one with a older new not used battery that was low on water. Filled and still nothing. The truck works just shows red battery. Turns out the one I took out is showing 23 volts and low on water also.
#2 eje 120, only works when the turtle button is pushed
The other is a emc 110, this one the key won't work unless held just right then the lift works and horn but the contacts click if try and move it, not fast or repeatedly they just click when try and move it.
One other question is a cat Diesel fork lift, not sure model, it don't have reverse. Use to work sometimes but now don't at all.
Switch in the tiller arm for the turtle button?
Macro switch on top of.motor for the emc110?
Thanks for any help
  • Posted 13 Jun 2023 13:02
  • By Montgomery
  • joined 13 Jun'23 - 1 message
  • Alaska, United States
Josh Montgomery
Bad battery issues can be either, bad battery plugs, one of battery's elements is dead, you should introduce load to each element and veridy it'll hold around 2V. There's a tool for that.
Also acid density should be measured, volts alone do not tell the whole story, unless you measure battery output volts under load(driving, lifting or those two combined).
Also worty to check contactor, emergency kill switch pins for even voltage.
Abouy turtle stuff, you shoulf check screen, battery led display for error /event messgas. If it shows 19xx you can be quite sure there's error in safety equipment.
  • Posted 17 Jun 2023 01:14
  • Modified 17 Jun 2023 01:15 by poster
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
I don't have a ton on jungheucirch experience but can tell you that no charging system or machine can operate without 24 volts...if they are separate batteries find the 4 that test at at least 5.2 at piece and run a series circuit to charger...see if charger kicks up voltage then...if doesn't after having descent batteries...issue with charger itself
On the one with contactor not closing verify 24 volts in and both positive and ground inputs sending in whatever is control voltage 12v or whatever...if all test good hit contactor gently when trying to activate...then hit drive motor gently one with work...that will tell you where the issue is
As for the forklift verify power when going forward at coil...then flip forward and reverse wires to see if drives
  • Posted 13 Jun 2023 13:45
  • Modified 13 Jun 2023 13:46 by poster
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
March 25-26, 2026 - Brisbane, Australia
May 12-14, 2026 - Singapore, Singapore
October 6-7, 2026 - London, United Kingdom
New Haven, Ct, United States
Researchers at Queensland's Griffith University are credited with taking the photograph of the smallest thing ever caught on film - the shadow of an atom, taken in 2012.
Zhejiang UN Forklift Co., Ltd
