Fault E 01-5
I have an ongoing issue with an 8FGCU25 and a check engine light - E 01-5. I have replaced the regulator ( for a rolling idle) and the O2 sensor. About 20 minutes into use the code reappears. The exhaust smells like rotten eggs as if a vacuum leak, but none found. On the screen I can see the O2 voltage fluctuate ( 21 - 38) and 0-1 switching. I have cleaned the carb, but not any of the valves as in prior posts. Any ideas?
  • Posted 6 Jul 2013 03:58
  • Modified 15 Jul 2013 23:42 by poster
  • By roadtek
  • joined 4 Dec'07 - 123 messages
Just in case you are still having troubles. Is it an early 8 series? They had problems with them running good but with that rotten egg smell being a problem with the ecu. If you work for a dealer, there should be some kind of bulletin on it.
  • Posted 31 Jan 2015 13:03
  • By Hero5
  • joined 17 May'14 - 56 messages
Take care of the customer
1-5 is lean condition. Check OX value. Replace inline filter
Might be low LP tank /. If the value flips back and forth from
1/2. Then it's acting normal, on-off-on. Etc, rebuild regulator and retest
  • Posted 27 Jan 2015 22:09
  • By ToyMasterTech
  • joined 27 Jan'15 - 13 messages
  • Maryland, United States
Not yet. But I will and will report back, thanks.
  • Posted 25 Jul 2013 13:05
  • By roadtek
You have to have the correct inj. time and vf voltage or will keep getting the code and idle issue. Did you pull the black valve on the side of the carb where the lp hose is? they can give you a idle issue.
  • Posted 25 Jul 2013 11:26
  • By rogeriwt
Anyone help on this? I am having the same issue with this code too.
  • Posted 24 Jul 2013 21:40
  • By TNLifttruckman
  • joined 3 Aug'11 - 7 messages
  • Tennessee, United States
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
Taylor T520S
Terberg RT223
