Fault Code
I have a customer that's Hyster shut down and is displaying a trouble code 523612-5
I have an old Yale trouble code sheet but the code is not in it.
Can someone out there give me an idea what that code means so I can have an idea of what we need to look at and repair? Thanks RA
  • Posted 30 Aug 2019 02:13
  • By ron_anderson
  • joined 30 Aug'19 - 3 messages
  • Utah, United States
Ron
That code was in my Yale trouble codes sheet.
Transmission valve calibration.
  • Posted 30 Aug 2019 03:16
  • By ron_anderson
Ron
Now this morning when the customer was trying to start it another code popped up, 522800-13.
Thank you for you help Brewski if I was in the area I'd buy you one!!!!!
  • Posted 30 Aug 2019 03:12
  • By ron_anderson
Ron
DTC 523612-5
Open Circuit of Harness or Coil in PCV Line
POSSIBLE CAUSE
A. POST NOX SENSOR WIRING FAULT
B. POST NOX SENSOR CANBUS COMMUNICATION FAULT
C. POST NOX SENSOR FAULT
  • Posted 30 Aug 2019 02:25
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
BREWSKI
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
