Fault code and limp mode
Wondering If I can get some help or a push in the right direction. The lift is showing a E0132 fault code on the display and its showing the dashboard light that looks like an bulb/flask with a spool or wire and an exclamation mark. The lift turns on but it's in limp mode. Pressing the accelerator does nothing. This happened after a leak under the cab. The hydraulic leak has been repaired. Since this error has started I have noticed it allows me to crank the engine and start it even if the parking brake is not engaged. I appreciate any assistance you may be able to privide.
  • Posted 12 Jul 2018 03:42
  • By Rikoku
  • joined 12 Jul'18 - 2 messages
Thank you, found the issue. The connector plug for the accelator was loose.
  • Posted 12 Jul 2018 06:41
  • By Rikoku
Accelerator Pedal or Lever Position Sensor 1 Circuit - Voltage Below
Normal or Shorted to Low Source.
  • Posted 12 Jul 2018 05:59
  • By BREWSKI
