I have a fault code of A displayed. The truck goes very slow with no hyd. If you turn the key off and then on, you get hyd. I checked the head cap. and found the neg. wire got hot and left scorch marks on the cap. What causes this? Any help? Thanks, Jim
to answer the question at hand
code A is:
Lift truck performance reduced. See Troubleshooting problem 5. Possible cause head capacitor failure.
and in the Problem 5 description it says:
Lift truck accelerates slower than normal with no lift.
- check the connections to the head capacitor and also the cables leading to the pos and neg heatsinks. Make sure they are tight and not corroded or burned. Check continuity.
check contiinuity on wire 34 to logics connector P2-2 , if good continuity then check head capacitor, if that is good then logics is bad.
Hi did you fin out what code A was ??
I have no power to wire 34. Cap charges very fast. connections look good. no burnt parts. need trouble shooting guide. please help. Cat microcommand
sent email let me know if you got it
please send info. check my profile for my email address. thank-you
I am sure adding the @ and sbcglobal.net will help...
why won't it allow me to recieve?
sorry. use jfr2006 @ sbcglobal.net. thanks, Jim
when I put "jim_v" in my email program, it refuses to send to you...
I would think most folks put a reply address in their profile or somewhere if they want someone to be able to email them.
google gives me 864 choices for "jim_v" ,,,, which one should I use?
please email me this. thanks, jim
E-mail me I will reply with code A troubleshooting. Email address in my profile
