Fault Code 2000-12
what is Fault code 2000-12
  • Posted 15 May 2016 07:23
  • By Clubberlang
  • joined 15 May'16 - 1 message
  • Arizona, United States
First check the 20amp fuses (small yellow fuse) in the fuse box next to battery. If the fuse has blown this code will show and will cause you problems. Check the simple things first then do what BREWSKI suggests.
  • Posted 21 May 2016 17:40
  • By luke_m
  • joined 2 Feb'13 - 97 messages
  • Bedfordshire, United Kingdom
CANbus error. Check the resistance of your can loop at the diagnostic port.
  • Posted 17 May 2016 22:53
  • By BREWSKI
Terberg YT222
Toyota 3FD100
VETTER Industrie GmbH
