Fault Code -04
This forklift just stopped moving, no fwd, no reverse, just the backup alarm. Still have hydraulics and steering.
The only fault code showing is a -04 with a green light on the little wrench on the display.
Before I start just blindly tearing into stuff, can anyone tell me:
1. What this code means
2. Why it's not listed in any manuals, books, or forums I've searched so far?
In one book with a fault list it jumps from -03 to -05. Almost suspicious, you might say.
Thanks in advance
  • Posted 24 Sep 2024 22:58
  • By Oatman
  • joined 24 Sep'24 - 11 messages
  • Kansas, United States
A.Oatman
Perfect, I'm glad you found the error.
  • Posted 7 Oct 2024 20:47
  • By Pablo
  • joined 19 Apr'24 - 12 messages
  • Argentina
Technician
Thanks everybody for the input.
So it turned out the operator brake pedal switch was stuck open. Stopped all voltage except for the horn in it's tracks.
  • Posted 5 Oct 2024 04:42
  • By Oatman
A.Oatman
Just a little info any code below -10
Is going to be for operator area ie
Brake switch, seat switch, forward and reverse switches and park brake switch
Example: -01 parking brake etc
  • Posted 25 Sep 2024 00:18
  • By John_Bradley
  • joined 10 Aug'22 - 295 messages
Jb69
Excellent, thank you very much.
  • Posted 25 Sep 2024 00:11
  • By Oatman
A.Oatman
Hello, I will transcribe what I have of information to you.
This status code is displayed when voltage at TB11-2 is less than 60% of battery volts initial start-up
Direccion control not in neutral at power up. Request traction
- Use proper sequebce for operating controls
It should be checked if any of the forward or reverse gear microswitches are not activated.
saludos
Pablo
  • Posted 25 Sep 2024 00:00
  • By Pablo
  • Argentina
Technician
Lift Tek Elecar
