Hi.
My unit is serial number=C1X335C52296 capacity=2000kg model =E20 P
Year= 2012 pls help im now repairing it hope you can help me with the error code L232
Info about the problem when you key switch on the unit
It will run for almost 3 minutes good condition and suddenly the after a few minutes the unit forklift will be slow running and if u try to key switch off it will stay slow moving wuth error L232 pls help
Also try to replace potentiometer,joy stick left and right still the erro code L232 appearing
SIR THE ERROR IS L232 NOT T232 TNX IN ADVANCE
Pls help me with this error code pls help
There have been times where a known bug was left in my code when going to production. On at least one occasion, the bug was a timing bug that we couldn't repeat reliably enough to be able to track it down before the release deadline. Eventually, I did figure it out, but it persisted in the code for several months. Because it didn't happen except under some specific circumstances, very few of our users ever saw it at all.
For more: https://www.hpsupport365.com/blog/how-to-fix-hp-printer-error-code-49/
Que tal buenos dias
Pudiste resolver la falla L323
Tengo el mismo problema
Saludos
CGB
[email address removed]
Que tal buenos dias
Favor su ayuda tengo una falla similar a la que se comenta en el inicio de la discusión
Falla L323 tracción lenta
Aparentemente debía ser hidráulico por la L pero es la tracción que se pone lenta
Saludos
hi am facing L 202 & T 292 ERROR IN MY 5 TON LINDE FORKLIFT
ANY ONE CAN SUPPORT ME IN THIS, HOW TO FIX I DONT KNOW
Steering Wheel Sensor Signal Faulty...
Hello, check on the bottom of the steering column, you have a switch, if that is ok you should have a problem with the steering sensor located in the steering column but check the connexions first.
Jos
