error code flashing e-34
We have a CAT P5000 forklift in the shop with a nissan engine(propane) and it is constantly flashing code e-34. Checked with local Cat dealer, says it is an overheating code but the temp gauge is always normal. Checked all wiring/fuses and connections, looked ok, tried the procedure given by dealer to clear code but it didn't work.
Could not find a temp sensor in the cylinder head.
Anyone have any idea what to look for?
  • Posted 27 Jul 2006 10:11
  • By ddrr
  • joined 27 Jul'06 - 16 messages
  • Alberta, Canada
Or undoing the battery.
  • Posted 11 Dec 2013 23:27
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
ddrr, check your ignition coils
yeah what edward said... try the pedal dance
if that doesn't work then you will have to clear the codes using the diagnostic tool or laptop
  • Posted 11 Dec 2013 22:39
clear the codes. either foot pedal dance or laptop/software. would have been better to start your own thread, with your error code, it would get more notice.
  • Posted 11 Dec 2013 22:26
I have a code E-33 and it also tells me its a temp sender but that is ok. I found v-belt got debris and caused it to come off but i reinstalled and unit ran fine with full power but i have all lights on dash are flashing. Any advice. C5000 with nissan engine, thank you
  • Posted 11 Dec 2013 14:52
  • By YaleTechnician
  • joined 11 Dec'13 - 18 messages
ignition signal has not been continuously genererated while the engine is running.
detect electric current in an ignition coil circuit,judge abnormal ignition interval and make mil go on
  • Posted 9 May 2013 01:00
  • By jesus_p
  • joined 9 May'13 - 5 messages
  • chihuahua, Mexico
You have the 4 cylinder engine. If this is true, E-34 is actually an ignition system error. It most likely has occured due to a misfire at some point in time. I'd start by checking the plugs and then move into other ignition system components (coils and their wiring).
  • Posted 27 Jul 2006 23:38
  • By 82elky
  • joined 27 Jul'06 - 1 message
Toyota 8FD30
Singapore
USD18,000
Aichi RX07B
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
Toyota 8FD30
Singapore
USD18,000
Aichi RX07B
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
