error code c016 e025
hi all,
My stacker is stuck and i have the error codes c016 and e025 showing. Any idea what the problem would be and how to solve it ? Thanks in advance for the help
  • Posted 14 Apr 2012 06:32
  • By Patrickk
  • joined 14 Apr'12 - 1 message
  • Papeete, French Polynesia
Patrick
11 Offset error armature /
field current (DC)
Stator current (AC);
Current measurement
point
F, H, L,
F-AC, H-AC
CONTROLLER Check main current wire, replace
component
Travel no function
  • Posted 24 Feb 2015 03:54
  • By joram_s
  • joined 5 Feb'11 - 117 messages
  • madrid, Spain
Hi
I have en error on EJE116 C016 and E011.
Whats is mean ?
How to solve this problem ?
Thank s
Anis
mydotanis(at)gmail(dot)com
  • Posted 24 Feb 2015 02:13
  • By junus_a
  • joined 30 May'12 - 49 messages
  • west java, Indonesia
you never walk alone
Hola.
71
Rotura de cable del potenciometro
de descenso.
I2, FS POTENC. DESCENSO Comprobar conexion de cables; cambiar
potenciometro de descenso; cambiar
Multipiloto; cambiar interface.
Mandame un mail.
  • Posted 30 Dec 2014 03:12
  • Modified 30 Dec 2014 03:13 by poster
  • By joram_s
  • madrid, Spain
Email soyjoram@gmaildotcom
Hola Joram
Podrias decodificar el E071 y C096 para el EJC110 con AS2409K ??
gracias
Luis
  • Posted 30 Dec 2014 02:21
  • By luis_y
  • joined 24 Oct'04 - 29 messages
  • Lima, Peru
All makes, the best service.
- no logon from
interface
- no telegrams from
Can-Bus travel switch
F, H, I4, I8
F-AC, H-AC
L
INTERFACE / CAN Check CANBus connection, check
wire connection between proportional
valve - modulation; check fuse 1F8;
replace iInterface (I2, I4, I8) ; replace
lift potentiometer, Multipilot, Solopilot
or interface;
MP1510C: Voltage collapses,
controller logs on again, interface does
not, controller remains blocked and
waits for interface.
Check battery voltage (with load!);
charge or replace battery if necessary;
AS2409K: no "live" telegram received
from CAN Bus travel switch for more
than 300 ms; replace travel switch
  • Posted 3 May 2012 20:56
  • By joram_s
  • madrid, Spain
Tampa Florida, United States
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
Still GX10
Still GX10 2000
Poland
EUR950
Taylor TX330S
USD159,500
