where can I find a diagram for this problem, I am having the same problem
ok i was mistaken, after looking through each code description i found it
Display = 68 or 69 action light flashes (!)
no lift truck operation
line contactor closes and opens
possible causes:
- (68) battery volts too low for chosen jumper
- (69) battery volts too high for chosen jumper
- short between connector P5-16 and P6-1
make sure the battery is ok, charged up and no frame grounds, voltage leaking from battery through case to frame can cause havoc on system
there are other possibilities such as bad display, bad logics, or open line contactor coil
sorry it took so long to get back on this...
good luck....
