error code 522762-4
hello i have a S50ft ser h187v03072n code is 555762-4 tsp switched battery ing 3 oorl i believe it is in the vsm i checked the pdm and is ok relay ok What is odd is the dash has the battery symbol and it flickers ,when key on before starting The forklift runs and hyd is working fine but i can not make it drive in either direction , Is there a walk around this problem or do i have to buy a new vsm/controller ? it has Manual hyd with operator presents any help would be wonderful thanks i will let you know what i find to fix this ? Ed
  • Posted 20 Oct 2022 01:39
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
Ok problem solved found the alternator battery stud rusty and eye to big on wire repaired and good I would like to tell you that the charging system was charging at 13.87 was not high enough it now charges over 14volts just a heads up thanks for anyone looking into this for me Ed
  • Posted 20 Oct 2022 23:42
  • By stillworkin
On the 88th day of the year, 29 March in a non-leap year and March 28th in a leap year, World Piano Day (also known as Piano Day) is celebrated. This date was chosen because a standard piano features 88 keys.
SMV (Konecranes) 4535TB5
August 1-3, 2025 - Coimbatore, India
September 18, 2025 - Blair Athol, South Australia, Australia
November 04-05, 2025 - Houston, TX, United States
