error code 225 e20 386 from 2008
hello the truck showing error L225 (pump not reach the required speed), some times go sometimes is not working since the outside temperature drooped below 15 degrades, all the summer went well, last winter also has this problem but when the heat came every thing worked well., we cheeked an the speed sensor is good, but the hydraulic motor is not spinning, sometimes after you erase the fault will work.
today we swapped the power module from another truck and it worked well 5 minutes and let it rest for 10 min and it shows the error and is not possible to erase it and the truck its stuck.
we cheeked in pathfinder the power module in said that is break in line between connection U and the engine,we checked the bars between power model and the engine and look ok.
what could be if sometimes is working ant sometimes not and its something with the cold
  • Posted 16 Nov 2018 07:31
  • Modified 16 Nov 2018 07:34 by poster
  • By daniel_a
  • joined 14 Mar'13 - 121 messages
  • ARGES, Romania
Check liftmodule for code 820.
Check if there is oil present in the axle.
Remove the covers with the connections from the axle, if oil present possibilty that coils hydr motor are damaged.
Underneath this covers are also cableconnections from the motors
Check coil resistance u v w, should be around 4 milliOhm and al 3 must be the same !! USE a milljohm meter and not a regular DMM
Had the same issue , had to replace axle with with another.
  • Posted 5 Jan 2019 22:58
  • By patrick_v
  • joined 5 Jan'19 - 61 messages
  • Netherlands
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
