error code -15
i am recieving error code -15 on display.
also is a flshing light on controller box like an 8.
1eop240961-15 serial.
am desprate for help
  • Posted 19 Dec 2012 11:33
  • By polecatizzy
  • joined 19 Dec'12 - 9 messages
  • Indiana, United States
Ok, here it is. Thank you
  • Posted 21 Dec 2012 15:22
  • By polecatizzy
Snydermark@embarqmail.com
Ok
[email address removed]
  • Posted 21 Dec 2012 15:17
  • By polecatizzy
Post an email in your profile as mine is as site strips out readable email address's
  • Posted 21 Dec 2012 15:00
  • By kevin_t
How.do.i.run learn
  • Posted 21 Dec 2012 14:57
  • By polecatizzy
Code H
Throttle Potentiometer (VR1) must be
learned.
Reason: A new firmware chip or new Interface Card has
been installed.
System Response: Interface Card Display: H
System Response: Traction Shutdown
How to Clear: Run Learn.
Code L
Throttle Learn Mode
Reason: Learn has been started
System Response: Interface Card Display: L
System Response: Truck Shutdown
How to Clear: Complete Learn.
  • Posted 21 Dec 2012 14:21
  • By kevin_t
-01 No Kill switch input
Possible Causes:
Misadjusted or defective kill switch.
Brakes not being released.
Check switch to insure proper closure.
Open circuit between battery positive TB3.
Check for loose connections or broken wire between
switch and TB3, between key switch and positive
side of the kill switch and between kill switch and
switch to TB4.
Check for loose connections or broken wire from
TB4 and to TB3.
Other symptoms not allowing brake release.
Check for error codes on the Interface Card.
If vehicle is equipped with electronic power steering,
check for error code.
Check status of emergency disconnect switch
  • Posted 21 Dec 2012 14:03
  • By kevin_t
i am now getting code -01 on display.
on the board the code is L and H.
any ideas
  • Posted 21 Dec 2012 13:59
  • By polecatizzy
any ideas
  • By polecatizzy
footswitch (deadman) and related wiring ok?
If unit has safety arms on either side of platform and IF it does and has enable switches in the arms, are they working ok?
  • Posted 20 Dec 2012 23:00
  • Modified 20 Dec 2012 23:01 by poster
got this fixed, but forks wont go up or down unless i engage solinoid by hand
  • Posted 20 Dec 2012 11:02
  • By polecatizzy
Code -15 is battery volts low,check your battery state of charge and the charger to make sure they are good,sounds like a low/weak battery.
Code 8 for controller box is as follows:
If lower is not requested and the voltage at the
Load Holding Solenoid is less than 1 volt for at
least 1/2 second.
Or
If lower is requested and the Load Holding
Solenoid voltage is greater than 1 volt for 1/2
second.
Corrective Action:
Corrective Actions and Checks:
1. Check the wiring between the Load Holding Solenoid and the
Interface Card (JPS5-2/JPS5-1). Check for both continuity and
positive connections.
With the key switch On, there should always be B+ on pin 2 of
the Load Holding Solenoid.
2. Connect a volt meter between JPS5-1 and TP4 on the contactor
panel. Turn the key switch On. If the voltage is less than 1 volt
without a code on the Interface Card, replace the Interface Card.
3. Check the Load Holding Solenoid for proper resistance.
Remember to run Learn if the firmware or Interface Card is
replaced
  • Posted 19 Dec 2012 20:58
  • By kevin_t
