Error 4:182
Hello Guys
My RRE 250E with serial number 6278463 is showing error code 4:182 after free lift pass the main lift (at 4+ meter level), I changed bearing sensor roller, wire and also adjust the wire but problem is still there. any suggestion? your support will be highly appreciated
thanks in advance
  • Posted 31 Mar 2020 18:47
  • By Ponting
  • joined 2 May'19 - 6 messages
  • Victoria, Australia
If the sensor gap isto big,core then 4 mm, it will not see the sensor, sometimes when the hit the metal guide, it deforms and the gap gets to wide, try pulling it back so the gap is two mil. All te way.
  • Posted 16 Feb 2021 06:25
  • By Joris_U
  • joined 29 Nov'18 - 7 messages
  • Belgium
If you have replaced another mast. Then you need to adjust the Parameter 1273 free lift accordingly.
Good luck
  • Posted 22 Jan 2021 01:30
  • Modified 22 Jan 2021 01:33 by poster
  • By tinhtinh
  • joined 30 Mar'19 - 33 messages
  • Viet Nam
tinh0972857693@gmail.com
Click on my user name, email is registered there
  • Posted 15 Jan 2021 07:02
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
Your email please
  • Posted 14 Jan 2021 22:56
  • By Ponting
No pulses from the main lift height
sensor during lifting/lowering.
Lifting disabled.
  • Posted 15 Dec 2020 21:49
  • By Roibeard
  • Dublin, Ireland
hi.
if you are sure sensor works well.
Can you check the 15V source at the sensor jack. without 15V source. Check the continuity to the controller. If everything is normal. I think you replace the controller.
  • Posted 5 Apr 2020 01:29
  • By tinhtinh
  • Viet Nam
I have some info on that issue, contact in Email please.
  • Posted 1 Apr 2020 19:30
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
