Error 4:180 4:195 3:314
Hello, in my BT RRE160 sn6257537(2013)
first of all I have 2 errors:
-after freelift when I try to lowering forks reachtruck do it very slow and i see 4:180 and sometimes i see error 4:195 and display shows a box with a question mark ? and 2 arrows pointing up after this.
The values on the hight indicator display are lost
I see in CID diagnostic (4) pos. 7&8 inputs change when B19 is rotated.
I replace valve Q2 - the error was not lost;
I replace MCU and after this error 3:314 appeared. although the fuse 73 is closed...
maybe someone has an idea how to fix it
Thanks
  • Posted 19 Mar 2018 16:32
  • By Sergmal90
  • joined 18 Sep'17 - 67 messages
  • Russia, Russian Federation
with kind regard
SergMal
smal-90@mail.ru
Q4
Main lift - lowering
Replaceable cartridge
Q5
Free lift - lowering
  • Posted 22 Mar 2018 20:59
  • By Sergmal90
I can win this problems
1) 4:180 - No pulses from the main lift height sensor
on lift/lowering.
1: Check the height sensor, battery voltage
or wiring harness as well as the wire for
the height indicator
2: Recalibrate the valve (Q4)
3: The fork load may be too heavy on
lifting.
Info from new SM.
In old SM i see this info:
"Check that hydraulic valve Q2 is open."
First of all after wrong information from the old manual, I replace the Q4 and Q5 valves, and the miracle as a result of the error E 4: 180 and 4: 195 as a result disappeared.
3:314 -
The MCU or ACT has not responded
via CAN2 within 70 ms.
The truck is braked until it stops.
1. Check fuse [F73].
2. Check that CAN 2 is intact in terms of
wiring harness, final resistance and
contacts. Disconnect the battery.
Check that the resistance between
[X130:8] and [X130:22] is 54 - 66
ohm.
3. Check that the ACT's green LED is lit
constantly.
If the LED is not lit:
* Check that the ACT has a supply
voltage of 48 V between [K1:9] and [B-].
* Replace ACT.
If the LED is lit:
* Replace ACT.
after all the checks I replaced the traction controller and the tractor started to work correctly
  • Posted 22 Mar 2018 20:57
  • By Sergmal90
with kind regard
SergMal
smal-90@mail.ru
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
Alogotransiphobia is the fear of being caught on public transport without a book to read.
Taylor T520S
UN Forklift FBT20NQZ1
Taylor T520S
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
