ERROR 347
Hello all.
I have an error code 347 at a e1.6-01 386 linde prodused 2013. does any body could tell me what to do. When I move joystick to any direction after a little bit the error occurs and then all functions goes slow.
Thanks in advance
  • Posted 8 Dec 2022 19:31
  • By Fanis
  • joined 8 Dec'22 - 9 messages
  • Greece
fanis
Many thanks for your reply
Please if you could tell me where are the sensors 3b3 , 3b4 because I don't have any schematics of the truck and x13:13 etc are the numbers of the cables on the controller?
Thanks in advance.
If you have any quastion of CROWN trucks please don't hacitate to ask me.
  • Posted 9 Dec 2022 20:11
  • By Fanis
  • Greece
fanis
Fault description:
Pressure in pressure accumulator is less than 25 bar
Conditions of occurrence:
Voltage at pressure sensor 3B3 less than 2.2 volts or voltage at pressure sensor 3B4 greater than 3.8 volts
Result:
Charging of pressure accumulator
Speed is reduced for all hydraulic functions
Driving speed is reduced to 7.2 km/h
Possible causes:
Cable connections between pressure sensors (3B3, 3B4) and controller (X13:13, X13:49, X13:44, X13:63) open, shorted or faulty
Pressure sensor defective
  • Posted 9 Dec 2022 01:32
  • By matt_s
  • joined 2 May'08 - 31 messages
  • kent, United Kingdom
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
September 29-01 October, 2026 - Cairo, Egypt
October 6-7, 2026 - London, United Kingdom
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
