Engine surging, hunts when throttle applied
Our Toyota lift starts fine, but engine speed control is very erratic. Engine surges and hunts, throttle response is sluggish. When throttle is applied, engine speed "hunts". Hard to have fine control because of this. Does not matter whether engine is cold or warm. I understand Toyotas use an electronic regulation/engine controller that is not adjustable. Heard somewhere to adjust distributor timing under load to get best performance. Is the dist. mech or vac advance? What is the correct setting w/timing light, procedure?
Thanks for any help!
  • Posted 7 Nov 2014 04:49
  • By gkitf16
  • joined 7 Nov'14 - 1 message
I seem to be having a vacuum issue where it wont open fuel vaporizer all the time, periodic. 8FGCU30 4Y, tune-up done, compression good, new sensor in dist, new vaporizer and cleaned fuel filter. When its in its bad mode it wont start unless i spray small amount of starting fluid in air cleaner housing. Spark testers show spark isnt an issue.
any help appreciated
  • Posted 21 Jul 2016 15:43
  • By Gassan
  • joined 16 Oct'10 - 21 messages
Check throttle body for dirt/gum build up and give it a good clean. Build up holds throttle open and causes issues.
  • Posted 28 Feb 2016 02:18
  • By BartTech
  • joined 2 Nov'14 - 8 messages
What did you find?
  • Posted 28 Feb 2016 01:15
  • By troy_m
A-Lift Services -- safe -reliable -affordable
oh dont mess with timing. You most likely need a throttle position sensor. The dead spots confuse computor, and make it think you are going up and down on the accel pedal. I'm assuming you're plugs and cap,rotor were checked?
  • Posted 15 Nov 2014 22:51
  • By EasiTek
June 9-11, 2026 - Stuttgart, Germany
edition #1268 - 12 February 2026
In this week’s Forkliftaction News we look at the life and legacy of Manitou Group’s Marcel Braud, who has passed away aged 93... Continue reading
Maxlion ESD15M
Taylor T650L
The term "Spring", referring to the season, originated in the 14th century as "Springing time", describing how plants "spring" or burst into life after winter. In the 16th century "Springing time" was shortened to just "spring" for the season of new growth.
