Engine surges runs rough at mid throttle if seat switch activated
No codes, if the seat switch is not activated the engine accelerates smoothly, when running rough, smells like rotten eggs. Vaporizer pressure 5.1.
  • Posted 5 Dec 2013 20:20
  • By mardabas
  • joined 25 Jan'12 - 18 messages
  • Michigan, United States
Found it, I was losing voltage thru the contacts on the controller relay. replaced the relay and problem solved. Thanks for all suggestions and help. I really appreciate it.
  • Posted 13 Dec 2013 20:34
  • By mardabas
that seems very strange about the seat switch...
On this unit, the Spark plugs and the rest of the ign. circuit should be good for at least 2500 hours.
does this unit ever get the engine compartment steam or pressure cleaned?
My WAG [Wild as Guess] about this is that you may have a load of corrosion that has run down from the battery into the wire harness connection on the top of the ECM, which (without a serial number is not possible to be sure) is mounted below the battery on the frame. -Any- moisture in that (something like 86 pin) connection can cause WIFs [Weird Intermittent Failure], and I always recommend that we put a few dabs of Dielectric grease on the pins before reassembly to force and keep the moisture out of that connection. NEVER use any other type of substance in that connection. the voltages and current flows in those connections is pretty small (lots of 5 vdc sensor circuits). if the Plastic cover to that connection is damaged in any manner, you will for sure want to get that part fixed, as this will be only the first of many WIFs caused by even very little moisture in that connection.
I would also suggest you check the engine oil level to insure you don't have a bad seal on the hydraulic pump. [also just a WAG]. the level will be high if the pump is leaking from the front seal, as the hydraulic oil will be leaking into the engine crankcase.
The "rotten egg" smell is 'normal' if your engine is running a bit rich, as it is the catalytic converter doing it's job, but why activating the seat switch makes it happen as opposed to [say] having the hood down or weight on the seat is a bit of a mystery. I still agree with Kevin T [above] that you are going to want to change out all the coil packs, if this motor is in the 7k and above hours range, and they have not yet been changed, as these motors run pretty decently on 3 cylinders, and you may not even notice the missing until you are down to 2 cylinders firing.
  • Posted 8 Dec 2013 23:29
  • Modified 8 Dec 2013 23:46 by poster
I change plugs every 1000 hours (OEM) drained vaporizer and cleaned screen. if the seat switch is not activated it runs fine. if switch is activated runs bad, even under a no-load condition.
  • Posted 6 Dec 2013 22:51
  • By mardabas
Another possibility is build up of tar in the Vaporizor.....MCFA has a tech bulletin out on this issue.....
  • Posted 5 Dec 2013 21:44
  • By kevin_t
How many hours are on it? Might just need a new set of OEM spark plugs...this has the Nissan K21/25 engine so USE OEM plugs.
  • Posted 5 Dec 2013 21:37
  • By kevin_t
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
