EE and F4 code Fashing Shuts down
I have checked 3 fuses and fuse wiring at dash,all look good.Also checked plugs and wiring on base of steering but have not removed display to check. Not sure if I am going in right direction. Thanks for any help.
Jason
  • Posted 1 Mar 2013 14:27
  • By bkjay
  • joined 1 Mar'13 - 3 messages
E0 is a main material Handling code and f1 is a display code. I'm thinking for my problem that it a static problem knocing out the display.
  • Posted 21 Feb 2014 14:06
  • By kerbi
  • joined 24 Sep'05 - 17 messages
I'm in the same boat. My codes came back after a month.Next I put in a refurb. card and display, now it has a EO and F1 code. So I'm about to blow my head off. Some please chime in If you can help.
  • Posted 21 Feb 2014 13:23
  • Modified 21 Feb 2014 13:24 by poster
  • By bkjay
I have the same problem
replaced the dash card unit ran good for a week both codes came back drives fine,
  • Posted 21 Feb 2014 12:45
  • By kerbi
I replace the display card and it fixed the problem
  • Posted 5 Jun 2013 08:36
  • By bkjay
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
Philadephia, PA, United States
Chandler, United States
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
