Easi picker no power.
So im working on an EASI OPC30TT. Serial EASI-96-AJ1672.
Truck came in for no lift problem. Found the limit switch at fault. Went to replace switch and the wires actually came out of the connector. Im assuming the B+ and B- wires touched because now i have no power throught the truck.
Strobe light works and accessory lights work. Display does not come on, PC contactor does not close, and i have no power to any of the cards. I checked all the main power fuses and fuses located on power card. All test good.
I cant get the PC contactor to close.
Any ideas?
  • Posted 3 Feb 2017 03:27
  • By kyle93
  • joined 4 Oct'16 - 13 messages
No problem
  • Posted 10 Feb 2017 09:55
  • By stam
Finally got the new fuse and installed it. Trucks up and running now. Thanks stam. Never wouldve seen that fuse.
  • Posted 10 Feb 2017 02:45
  • By kyle93
There is a small cylinder fuse mounted on the tractor manager. It's the size of a pencil rubber, 2.5 amp I believe. Have a look.
  • Posted 3 Feb 2017 05:58
  • By stam
Toyota 02-2TD20
Ncn 110TH
Ncn 110TH 2015
