e-3000 ac speed control
Not looked at this truck yet but can you slow these down so operator cant change through dash?Also has anyone had pump failures with this unit?
  • Posted 10 Nov 2009 01:27
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Thank you Ed these units rip the splines off the pump.Customer said it was rusty on the splines
  • Posted 10 Nov 2009 10:03
  • By proshadetree
you are far more likely to have a clogged up relief valve in the main hydraulic control valve or motor turning too slow than a pump problem but there have been some. (not many) be sure you have an A/C clamp on amp gage when you go to check it out, to insure the amps are good, as well as the pressure.
As I remember it, with the laptop (or the D-R-S switch), you can either set all the setups for a slower speed, or you can set the unit up as an EE unit and that will prevent higher speed, and higher amps on a ramp, and prevent the changing of the speed with the dash
  • Posted 10 Nov 2009 08:08
Saratoga, United States
Columbia, SC, United States
East Syracuse, United States
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
