Drive unit gasket
Hi everyone,
I'm looking for the drive unit cover/housing gasket part#. Drexel said there isn't one,but mine does have a gasket. The truck is a Model#SLT-30, Serial# 902732-168. The Drive unit is made by Durst,and it has a Model#SW5516LS06, Gear Ratio 14.33:1.0 , and Serial#019180. Any help would be appreciated.
  • Posted 20 Jun 2007 07:42
  • By Truck_Tech
  • United States
Chris, You are right. I did find the fill plug there and as it would have been a lot more trouble to squeeze the gear lube through a small tube I removed the drive motor to clean the cavity and inspect the pinion drive gear as well. It took 7 1/2 quarts to fill it to the level required. Thanks for the input.
  • Posted 19 Apr 2015 21:06
  • By IndyHysterGuy
  • joined 8 Apr'15 - 10 messages
  • Indiana, United States
Indy,
How old is your truck? Is the steering done through gears or a chain?
Either way, if you turn the gearbox so the wheel is pointed away from you, the upper plug should be just under the gear/chain to the left side. To be honest, this is tucked up in there so that it would really be easier and take less time for you to pull the motor off and fill the gearbox from the top. It is not really that big of a task, and you only need to pull it up enough to get a funnel down in there. We have done this without even disconnecting the electrical from the motor.
  • Posted 16 Apr 2015 22:13
  • By ChrisK
  • joined 28 Feb'14 - 142 messages
  • Kansas, United States
some of these drive units just used gasket sealer but sometimes they would come from the factory with a gasket on them but the number would not show up in the manual.
if there is a gasket on the cover plate though and you just feel better having one, go to the parts store like NAPA and get some gasket material and make yourself one :o)
  • Posted 9 Apr 2015 10:17
I am curious about checking the drive unit gear lube level in one of these SLT30s and am unable to find an upper plug or weep hole. I would like to change the fluid and would like to know the gear lube capacity as well. Surely we don't have to remove the drive motor to add fluid after draining the old gear lube using the drain plug, or do we?
  • Posted 9 Apr 2015 05:09
  • By IndyHysterGuy
anarobic works great try it you'll like it ,mikey like,s it;s locktight makes it
  • Posted 31 Dec 2008 13:09
  • By douglasmhec
  • joined 24 Dec'08 - 5 messages
just use a good gasket maker and "fagitaboutit" it will be fine
  • Posted 12 Sep 2007 07:54
  • By twetnysevnyrtec
  • joined 26 Aug'04 - 21 messages
ATEX | MIRETTI GROUP Explosion Protections
Miretti Explosion Proof Systems for Material Handling: for over 50 years, "Ex Atex Safety in Explosive & Hazardous Areas".
Stu Jacover Stu Jacover
Chief executive officer, TVH
