Diesel in petrol engine
I have accidentally put diesel in a petrol run TCM Forklift, not sure if this is the correct model.
Either way I put about 20 litres of Diesel in the tank and drove it a short distance before realising my mistake. I immediately syphoned the tank and filled it with normal unleaded. Even through all of this when i went to start it it just sh*t itself and wouldn't start. It is turning over, but there is no real sign of the fuel igniting. Im not sure if i have stuffed the spark plugs or completely stuffed the engine. If you have any experience with this issue I would really appreciate your help with steps to take to fix / remedy my problem, including signs of what could be indicitive of different issues that may have arisen from my stupidity.
Cheers!
  • Posted 27 Jul 2008 23:34
  • By MikeMck
  • joined 27 Jul'08 - 1 message
  • Victoria, Australia
lol i had a customer do this once
although they hadnt realized the mistake at first
i couldnt tell what fuel was in there siince it was a sewage treatment plant and the tank still had a strong gasoline odor
a few hours later the operator fessed up and said he filled it with diesel
if youre not a mechanic i would suggest calling one due to the dangers of working with petrol (gasoline gas etc)
change the spark plugs and fuel filter dont mess with the carb at all (yet) since it ran ok before (or if you got some skill drain and clean out the bowl)
if you have an h20 nissan engine the gap for the plugs is.028" -.031" (.711mm -.787mm)
and for the j15 its.031" (.787mm) -.035" (.889mm)
after changing the filter and plugs run it out of a clean gas container (not from the tank) and be careful of static discharge
leave the tank on the ground
get it running like that then
the gas tank (petrol tank) should have a plug in the bottom to completely drain it
if you still cant get it running send the carb out to have it checked or rebuilt
i dont think the diesel would present a problem in the engine itself the one i had above still runs fine
the compression isnt high enough in a petrol motor to ignite the diesel
diesel is explosive under high heat and high pressure
most diesels are in the 20 to 1 range where this motor is probably closer to 10 to 1
i used to work at a diesel fuel shop and ppl would fill diesels with gasoline by mistake all the time
those were ugly and expensive
  • Posted 28 Jul 2008 02:54
  • Modified 28 Jul 2008 02:55 by poster
  • By justinm
Still GX10
Still GX10 2000
Poland
EUR950
Hangcha CBD15
China
USD1,600
edition #1285 - 11 June 2026
Stu Jacover Stu Jacover
Chief executive officer, TVH
