Dead cat Nrr40
We have a cat Nrr40 electric isle stacker that was running fine untill we slid the battery out to check water and charge.Slid the battery back in then plugged up i think the keyswitch was on at the time and now nothing. Ive checked all the fuses there ok.There no display on the panel any ideas?????????
  • Posted 19 Aug 2011 10:51
  • By chip_w
  • joined 19 Aug'11 - 2 messages
  • Mississippi, United States
Checked the truck today and no it doesnt have a gate switch at the battery.Talked to the guy today that done the charging and he admitted when he slid the battery back in he accidentally plugged the charger plug into the lift and turned the key on.He said the display on the dash came on momentary then went off. After that nothing no display on dash not anything.Any help on this thing will be greatly appreciated. Thanks.
  • Posted 20 Aug 2011 08:59
  • By chip_w
since the problem started after you slid out the battery. are you POSITIVE you did not charge the truck instead of the battery?
Some of these units had an optional battery gate switch, that required the battery holding brackets at the sides to be properly installed, have you checked to see if that is your problem? does the dash give any clues or codes or messages?
  • Posted 19 Aug 2011 20:03
