dead batteries
I had new batteries installed by Crown in December or January. My guys forgot to plug the stacker in and now the batteries are dead. I tried to put them on trickle charge but nothing. Is there possibly a trick to get these batteries to charge without calling Crown out again?
  • Posted 7 Jun 2025 12:41
  • By Kevin_Clark
  • joined 15 Aug'21 - 26 messages
are you saying 1 12v battery attached to 2 of the 6volts? and then probably do it again for the other 2 batteries? And wire them in series or parallel?
  • Posted 10 Jun 2025 04:54
  • By Kevin_Clark
If you have a jump pack, you can place the clips across 2 batteries (12v) and jump it. That should get the voltage high enough for the on-board charger to start.
That all depends on how low the voltage is and if there are any possible dead batteries.
  • Posted 9 Jun 2025 20:55
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 226 messages
  • Wisconsin, United States
March 18-19, 2026 - Birmingham, United Kingdom
