Crown INFO LINK SYSTEM
Hello Crown Experts. I'm looking at moving a customers Crown Infolink system off of his forklift and installing in onto a Toyota.
Can anyone supply wiring info, or installation instructions so that I can see if its even possible?
Thanks!
  • Posted 9 Sep 2021 08:29
  • By Sean_H
  • joined 9 Sep'21 - 3 messages
  • Alberta, Canada
Tech267
I install Infolink systems On all types of forklifts. Crown has little to do with it. The pn for the universal wiring harness is 140023-001
  • Posted 9 Aug 2024 22:49
  • By erik_hagelberg
  • joined 8 Apr'24 - 7 messages
  • Tennessee, United States
Sorry, I can't help with that. I would call Crown in Canada. I'm sure their InfoLink division would be able to answer your question. Keep us updated if you are able to do it. I was under the impression that in order for it to work it had to go through Crown IT. I may be wrong.
  • Posted 10 Sep 2021 07:51
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
I only need a few features from it to work.
- Impact detection
- Operator access using a code or RFID
- Maintenance tracking
- The ability to lockout the forklift.
I do not need error codes to reported by the system.
If the Infolink has a built in hour meter and impact sensor(s) along with a 'key on' input and a way to interrupt the key switch, I should be able to make it work of a Toyota, right? I'm still trying to get the model of the infolink from my customer.
Thank you.
  • Posted 10 Sep 2021 04:34
  • By Sean_H
  • Alberta, Canada
Tech267
Unless Crown factory has a harness for the truck you want to install it on it will not work. The InfoLink communication goes through Crown and has a high cost to configure/monitor. I have never seen InfoLink on anything but Crown trucks. You need to call them to verify what I said. 419-629-2311. They have an InfoLink division.
  • Posted 10 Sep 2021 02:39
  • By 1CrownTech
Thanks for the response. I have pictures, and I'm trying to get a model.
  • Posted 10 Sep 2021 00:13
  • Modified 10 Sep 2021 00:14 by poster
  • By Sean_H
  • Alberta, Canada
Tech267
need more info
early style infolink or canbus
probably not worth the effort
  • Posted 9 Sep 2021 21:02
  • By crownie
  • Victoria, Australia
Maxlion FD25
UN Forklift FD20-35FJM3
