Crown 20MT Stacker
Greetings from Florida! New member and first time poster.
I have been perusing the site as I just purchased a used/abused 20MT Stacker that has no power. Seller purchased 3 propane forklifts and let the walkie sit. He states that it ran when they parked it. Owned by a little old lady from Pasadena that never operated it in rabbit mode. Well, I made the last part up, but it doesn't look too bad on the outside. The inside is a cluster...
First thing I plan on doing is pulling the batteries and charging them on the bench. Not sure how I'm going to do that yet. I have 6 and 12 volt chargers, but I'm thinking they should be charged together at once. Any suggestions would be appreciated.
Next I will disconnect and clean all of the connections and there are plenty of them! There is quite a bit of information available on this site thus the reason for joining. I will be watching the forums and any replies to this post.
Edit: I now know the motors are in working order! I direct wired a 12v battery to the lift motor just to see if it was DOA and it lifts beautifully! Also wasn't thinking that was going to bypass the drive motor as well but it did, and that works too at least in slow speed. I'm pretty stoked to have picked this up for 320 bucks!
Jay
  • Posted 26 Aug 2019 08:06
  • Modified 26 Aug 2019 09:01 by poster
  • By Kikstand
  • joined 26 Aug'19 - 6 messages
Don't think... Just DO IT!
Could you please send me the wiring diagram I'm having fun with one not going into top speed [email address removed]
  • Posted 22 Oct 2019 06:19
  • By Bazza
  • joined 27 Jun'12 - 17 messages
  • S. Wales, United Kingdom
barrysmartlift@gmail.com
"i think you'll find getting the batteries back in shape will probably fix your issue with it.
If they sit too long they loose charge, sometimes you can get them to charge back up, but sometimes they just die and have to be replaced.
I would put a trickle charge on each one and bring it back slowly.
You can do each one individually or in pairs , how ever you wish.
Just make sure you mark the cables so you won't get them out of order of connection.
Once you get them charged back you can come back if any other problems arrise and work out those problems then.
good luck "
I certainly appreciate that Swoop!
I have hopes that charging in series of two paralleled together with a 12v trickle-charger via my pulse charger will slowly bring them back if they can be brought back.
  • Posted 27 Aug 2019 07:10
  • By Kikstand
I already have the wiring diagrams prepaito_d but Thank you!
  • Posted 27 Aug 2019 06:40
  • By Kikstand
Is 4 batteries but 12 volts system, I can send wiring diagram contact me by email
  • Posted 27 Aug 2019 06:30
  • By prepaito_d
  • joined 17 Dec'17 - 177 messages
  • iztapalapa, Mexico
Whatsapp +525513637801
good luck
  • Posted 26 Aug 2019 16:17
